Configuring the Texas Digital OCB Settings
Starting with Simphony 19.6, the extension application
function TxDigitalOcbApp.dll is part of the core software product
and is deployed via the Client Application Loader (CAL). Upgrading
to Simphony 19.1 or later changes the content Version (shown in the
Extension Application module, Designer: Settings tab) from DLL to (any)-19.1. For backward compatibility, no new changes are
required in EMC. However, for new Simphony 19.6 installations, only
the Settings content is required (the App content is not required).
The following sample shows the initial OCB display settings, which you can modify as needed. The tables that follow the code sample describe the values in the code.
Tip:
Click Copy to copy the code to your clipboard and then paste it into a text editor such as Notepad++. Change the values for your restaurant’s OCB operations, and then copy your code into TxDigitalOcbAppSettings.txt as described in Adding the Texas Digital OCB Extension Application.{ ; OCB Displays
DisplayIdentifiers=DisplayA
DisplayA.Name=Drive Thru Display
DisplayA.Protocol=TDSv2
DisplayA.Address=192.168.0.231
DisplayA.Port=5557
; POS OCB Options
MenuItemNamePriority=3,1,2
OcbEnabledOnOrderTypes=3
ShowItemDiscountAsModifier=true
HideQuantityOnDiscount=true
MenuItemModifierShowsQuantityWhenOne=1001
; Workstation OCB Options
Workstation-1.DefaultDisplay=DisplayA
Workstation-1.PromptToClaimOcbIfNotActive=true
Workstation-1.ReleaseOcbAtEndOfOrder=true
Workstation-1.EnableOcbOnPickupCheck=false
Workstation-1.EnableStickyDisplaySelection=true
Table 6-11 Main Setting
| Name | Default Value | Description |
DisplayIdentifiers |
DisplayIdentifiers=DisplayA |
A comma-separated list of identifiers, one for each physical display. Each identifier is used as part of the configuration and cannot contain an equal sign (=). The identifier is not displayed to the user.
Table 6-12 OCB Display Settings
<display-id>.Name |
The name of the display shown to the user. This can be more descriptive than the Display Identifier. |
<display-id>.Protocol |
TDSv2 |
The name and version of protocol used by the display. |
<display-id>.Address |
The TCP address of the display. |
<display-id>.Port |
The TCP port of the display, |
Table 6-13 General OCB Behavior
OcbEnabledOnOrderTypes |
Comma-separated list of order type numbers. Information is only sent to the OCB display for an order started/changed to one of the listed order types.
MenuItemNamePriority |
1,2,3 |
The order in which the application looks at menu item Name 1, Name 2, and Name 3 to determine which text is sent to OCB for the menu item. The same setting is used for both menu items and condiments.
ShowItemDiscountAsModifier |
true |
Flag used to control how item discounts are displayed. Set
to |
HideQuantityOnDiscount |
true |
Flag used to control how quantity is displayed for discount
lines. Set to |
MenuItemModifierShowsQuantityWhenOne |
false |
Comma-separated list of major group numbers. If menu item is in one of the listed major groups, modifier quantity is displayed when quantity value is 1. |
Table 6-14 Workstation OCB Behavior
Workstation-<ObjNum>.DefaultDisplay |
The display-id of the OCB to which the workstation sends orders. Leave this value blank to compel the user to activate an OCB device. |
Workstation-<ObjNum>.PromptToClaimOcbIfNotActive |
false |
If an order is started or changed to an order-type in the OcbEnabledOnOrderTypes list, and there is no default OCB display and no active OCB display, then prompt the user to claim an OCB display. This option is used to ensure that information is sent to the OCB display. |
Workstation-<ObjNum>.ReleaseOcbAtEndOfOrder |
false |
Set to |
Workstation-<ObjNum>.EnableOcbOnPickupCheck |
false |
Set to |
Workstation-<ObjNum>.EnableStickyDisplaySelection |
false |
Set to This allows users to switch from a mode where the OCB display is selected at the start of every transaction to a mode where the OCB display selection is retained. The Deactivate Display operation clears the sticky selection and reverts to "Prompt on every transaction" (if configured). |
Table 6-15 Workstation OCB Behavior by Order Type
| Name | Type | Description |
Workstation-<ObjNum>.OrderType-<Num>.DefaultDisplay |
Workstation-<ObjNum>.OrderType-<Num>.PromptToClaimOcbIfNotActive |
false |
If order is started/changed to an order-type in the OcbEnabledOnOrderTypes list, and there is no default OCB display and no active OCB display, then prompt the user to claim an OCB display. This option is used to ensure that information is sent to the OCB display. |
Workstation-<ObjNum>.OrderType-<Num>.ReleaseOcbAtEndOfOrder |
false |
Set to |
false |
Parent topic: Texas Digital Order Confirmation Board (OCB)
