Allowing Employees to Add or Transfer Checks
- Select the Enterprise level, click Configuration, and then click Roles.
- Double-click the role type record (for example, administrator, manager or server).
- Click the Operations tab, and then click the Guest Checks subtab.
- Select the appropriate permission options for the user
role:
Table 25-10 Transfer of Check Permissions
Option Select to allow employees with this role to transfer checks... 45 - Authorize Transfer of Checks in the Same Revenue Center
From another operator within the same revenue center.
46 - Authorize Transfer of Checks Between Revenue Centers
From another revenue center.
47 - Authorize Adding of Checks in the Same Revenue Center
To be in a check, and add another check to it within a revenue center.
48 - Authorize Adding of Checks Between Revenue Centers
To be in a check, and add another check to it from another revenue center.
- Click Save.
Parent topic: Check Add/Transfer
