Allowing Employees to Reprint Closed Checks
- Select the Enterprise level, click Configuration, and then click Roles.
- Double-click the role type, click the Operations tab, click the Printing subtab, and then
select the appropriate options:
Table 25-9 Check Reprinting Options
Option Description 23 - Authorize/Perform Unlimited Reprinting/Printing of a Check
Select to allow employees associated with this role to perform two functions:-
Allow On-Demand operators to print more guest checks than the maximum number allowed.
Allow By-Round operators to use the Reprint Closed Check key.
Selecting this option also allows employees to grant authorization to others for these functions.
24 - Authorize/Perform Reprinting of Closed Checks
Select to allow employees with this role to reprint a closed guest checks and to authorize others to do so.
- Click Save.
- Select the Enterprise, property, revenue center, or zone, click Configuration, and then click Page Design.
- Open the Front of House page on which to place the Reprint Closed Check buttons.
- On the Edit tab, select the page area in which to define button.
- Click Button, and then on the General subtab, select Function from the Type drop-down list.
- Click the black arrow directly beneath the Type drop-down list, and then select Print from the Type pane.
- Select Reprint Closed Check, and
then click OK.
When this function key is used, the Default Reprint Check Tender assigned in Tender Parameters is used to print the check.
- Enter a Legend for the button, and then position and size the button on the page.
- Repeat steps 7 through 10 to create a Reprint
Previous Closed Check button.
This function key is used to reprint a receipt for the last closed check.
- Click Save.
Parent topic: Closed Guest Check Operations
