PreviousNext
JavaScript must be enabled to correctly display this content
Configuring Memo Check Printing
Select the Enterprise or property, click Configuration, and then click Tender/ Media.
Insert a new record, name it Print Memo Check, and then click OK.
Double-click the Print Memo Check record to open it.
From the Key Type drop-down list,
select 2 - Service Total.
Click the Options tab, click the Printing Options subtab, and then select the following
options:
13 - Print Memo Check: Select to allow
this key to print memo checks.
(Optional) 15 - Increment Active Seat # after Memo
Check Print: Select to increment the active seat number
on the seat filter or active memo check number to the next number
each time this key is used to print. This allows workstation operators
to (in succession) generate memo check or to apply memo tenders. When
this option is selected, pop-up operators remain signed in when the
seat filter is reset. Deselect to reset the seat filter when this
Select 13 and (optionally) 15 for all tender medias that can be used for memo tendering.
Click Save.
Select the Enterprise, property, revenue center, or zone,
click Configuration, and then click Page Design.
Open the page on which to place the memo check button.
On the Edit tab, select the page
area in which to define the buttons.
Click Button, and then on the General
subtab, select Tender/Media from the Type drop-down list.
Click the black arrow beneath the Type drop-down list, select Print Memo Check from
the list and then click OK.
Enter a Legend for the button (for
example, Print Memo Check), and then position and size the button
on the page.
Click Save.
(Optional) To prompt for the guest count for memo checks:
zone, click the Setup tab, and then click Control Parameters.
Click the Options tab, and then
select 9 - Prompt for Guest Count when Split Check.
