PreviousNext
JavaScript must be enabled to correctly display this content
Configuring Default Headers and Trailers
Select the Enterprise, property, revenue center, or zone,
click Descriptors, and then click either Guest Check Headers or Guest Check Trailers.
For each row, enter information in the following fields:
Text: Enter the text to appear on the
header or trailer.
(Optional) Use Logo: Select this option
to print a logo rather than text on the guest check header or trailer.
(Optional) Logo: If you selected Use Logo, select an image.
Click Save.
To configure trailers to print for each tender media record,
select the Enterprise, property or zone, click Configuration, and then click Tender/Media.
Double-click the tender record.
Click the Options tab, and then
click the Printing Options subtab.
Set the appropriate options as described in the following
table:
Table 25-1 Trailer Printing Options
Option
Description
20 - Print Sales Itemizers
Select this option to print the sales itemizer lines on
guest checks, customer receipts, and memo checks when workstation
operators use the tender record. Deselect this option to suppress
printing of the sales itemizers.
21 - Print Summary Totals
Select this option to print the summary totals (subtotal,
tax, amount due, and change due) on guest checks, customer receipts,
and memo checks when workstation operators press the key. Deselect
this option to suppress printing of the summary totals.
22 - Print Check Trailer
Select this option to print the guest check trailer lines
at the end of the guest check.
28 - Print Guest Check Trailer on Fast Transaction Customer
Receipt
Select this option to print the guest check trailer on the
customer receipt when workstation operators use the tender to close
a fast transaction. Deselect this option to prevent the trailer from
printing on customer receipts.
