Configuring Smart Keys for Enterprise Cash Management
For Enterprise Cash Management users, a smart key prevents the use of a workstation until you assign a till session to a cash drawer on the workstation. After assignment, the key permits the workstation operator to sign on to the workstation. Follow these steps to implement the optional smart key.
- Select the Enterprise, zone, property, or revenue center, click Configuration, and then click Page Design.
- Select the Sign In page.
- On the Edit tab, click Button.
- Enter information in the Page Design fields.
Table 44-4 Page Design Edit Fields
Field Entry Legend
Enter the name of the button (for example, Till Status).
Type
Select Function from the drop-down list.
Sub Type
Click the black arrow, and then select Smart Key.
Auto Active
Select this option to make the button automatically active.
- Click the Edit Smart Keys button.
- Click Add.
- Enter information in the fields as described in the following
table for Smart Key entry number 1.
Table 44-5 Smart Key 1 Fields
Field Entry Condition
Select Till Assigned from the drop-down list.
Value
Enter 1.
Legend
Enter the name of the button (for example, Sign In).
Type
Sub Type
Click the black arrow, and then select Sign-In.
- Click Add.
table for Smart Key entry number 2.
Table 44-6 Smart Key 2 Fields
Select Default from the drop-down list.
Value
Enter 2.
Legend
Enter the name of the button (for example, Assign Till).
Type
Sub Type
Click the black arrow, and then select Assign Till To Cash Drawer.
- Click Close, and then click Save.
Related Topics
Parent topic: Enterprise Cash Management
