Configuring the EMC Translation Files
When you add a new language or after the Simphony Cloud Service has been upgraded, you need to import the translation files for each local language you want to use or that you have configured.
To configure translated text files for the EMC:
- Select the Enterprise, click Setup, and then click Languages.
- Double-click the language record to open it.
- Click the Translation tab.
- To access a standard translation file:
- To manually import a translation file for each language
used:
- Click Save.
Parent topic: Language Settings and Translation
