Setting the Default Language for a Workstation
You can configure the language that appears on the POS UI Sign-In page.
Employees with a different language configured see their default language after signing in to the workstation.
The CAPS workstation requires the translation files, so the ad hoc reports for the workstation operator who is signed in show the report in the his or her assigned language.
- Select the property, click Setup, and then click Workstations.
- Double-click a workstation record to open it.
- On the General tab, select the Language to appear on the workstation device, and then click Save.
- Repeat Steps 2 and 3 for all workstations.
Parent topic: Language Settings and Translation
