PreviousNext
JavaScript must be enabled to correctly display this content
Translating Touchscreen Buttons
Select the Enterprise, property, revenue center, or zone,
click Configuration, and then click Page Design.
Open the page to translate, and then on the Edit tab, click the Translate current item
legend ()
icon.
In the Edit Content Area Translated Text dialog, enter
the translation for each button in the relevant language column.
The dialog shows a separate column for each language assigned
to the current property in Property Parameters. Each row in the grid
represents a single touchscreen button.
