Configuring Print Groups for Menu Item Classes
  1. Select the Enterprise, property, revenue center, or zone, click Configuration, and then click Menu Item Classes.
  2. Double-click a menu item class to open it.
  3. On the General tab, select a Print Group for the class.
    When the items are set to use print groups for sorting, the items appear from lowest group number to highest.
  4. Click Save.
