Configuring Privileges to Edit Menu Item Definitions and Prices
In the EMC, you must grant permission to edit menu item definitions and prices. The permissions enable workstation operators to change menu item definitions and prices at the property level from the workstation using the Edit Menu Item function key. The Oracle Hospitality Simphony Manager User Guide contains more information on Adjusting Menu Item Definitions.
Users cannot edit a menu item that is defined at the Enterprise or zone levels; users with the appropriate privileges can edit a menu item that is defined at the property level.
- Select the Enterprise level, click Configuration, and then click Roles.
- Select the role type, click the Operations tab, and then click the PMC Procedures sub-tab.
- Select options 30020 - View Menu Items to enable employees to access menu items from the workstation, 30021 - Edit Menu Item Definitions to enable employees to edit menu item definitions from the workstation, and 30022 - Edit Menu Item Prices to enable employees to edit menu item prices from the workstation.
- Click the PMC General/Reports sub-tab.
- Select 30001 - Run PMC to allow employees associated with the role to launch the PMC on the workstation using Function Key 300, Launch PMC.
- Click Save.
Related Topics
Parent topic: Creating Roles
