Discount Number Lookup (NLU)
  1. Select the Enterprise or property, click Configuration, and then click Discounts.
  2. Double-click a record, and then click NLU/SLU.
  3. Enter a unique NLU number for the discount.
    You can enter a value between 1 and 255.
  4. Click Save.
  5. Repeat Steps 2 through 4 for all discounts to appear in the number look up.
  6. Select the Enterprise, property, revenue center, or zone, click Configuration, and then click Page Design.
  7. Double-click the transaction page on which you want the number look up to appear on the workstation.
  8. Insert a new button, select Function from the Type drop-down list, select Discount NLU from the Function list, and then click OK.
  9. Click Save.
