Menu Item Number Lookup (NLU)
You can create NLUs for retail menu items (for example, bottled wine, t-shirts, and hats).
  1. Select the Enterprise, property, revenue center, or zone, click Configuration, and then click Menu Item Maintenance.
  2. Double-click a menu item, and then click the General tab.
  3. Select the relevant NLU Group from the Number Lookup Properties section.
  4. Enter a unique NLU Number for the menu item. Up to 12 digits are allowed
  5. Click Save.
  6. Repeat Steps 2 through 5 for all menu items to appear in the number look up.
  7. Select the Enterprise, property, revenue center, or zone, click Configuration, and then click Page Design.
  8. Double-click the transaction page on which you want the number look up to appear on the workstation.
  9. Insert a new button, select Function from the Type drop-down list, select Menu Item NLU from the Function list, and then click OK.
  10. Click Save.
