Major Group Screen Lookup (SLU)
  1. Select the Enterprise, property, revenue center, or zone, click Configuration, and then click Page Design.
  2. Double-click the transaction page on which you want the screen look up to appear on the workstation.
  3. Click Other in the Page Design toolbar, and then click Sales SLU.
  4. Select Menu Item from the Type drop-down list, select Major Group as the Property, and then select the major group to show in the screen look up as the Value.
  5. Select the Menu Item Display Name.
  6. Click Save.
