Menu Item Screen Lookup (SLU)
You can assign each menu item definition to a maximum of eight different SLUs in table view of the Menu Item Maintenance module. Assigning multiple SLUs to a menu item allows flexibility in building POS client pages that are customized to use dine in, carry out, and curbside to go, and shows the menu items supported by the order type.
Parent topic: Deliveroo
Parent topic: DoorDash
Parent topic: Rappi
Parent topic: Skip
Parent topic: Uber Eats/Postmates
Parent topic: Screen Lookup (SLU)
