Creating the Declare Waste Button
To declare waste, you need to add the Declare Waste function key to a page.
- Select the Enterprise, property, or revenue center, click Configuration, and then click Page Design.
 - Open the page on which to place the Declare Waste button.
 - On the Edit tab, select the page area in which to define the Declare Waste button.
 - Click Button to add a button.
 - On the General subtab, enter the button name in the Legend field.
 - Select Function from the Type drop-down list.
 - Click the black arrow directly beneath the Type drop-down list, and then select Declare Waste.
 - Highlight the Declare Waste button.
 - Position and size the button on the page. Use the Style arrow to change the color.
 - Click Save.
Parent topic: Menu Item Waste
