PreviousNext
JavaScript must be enabled to correctly display this content
Generating the Module Reference Report
Select the Enterprise level, click the Tasks tab, and then click Module Reference Report.
Select the appropriate Report Type:
By Name: Select to search for menu items
by name.
By Number: Select to search for menu
items by record number.
Click Select Items for Report, select
the menu item names or numbers to include in the search, and then
click OK.
Select multiple menu items by pressing the CTRL or SHIFT
key while selecting an item. You can select a maximum of 50 items
at a time.
Click Run Report by Name or Run Report by Number to generate the report.
To print the report, click the Text View tab, and then click Print.
To save the report as a text file, click the Text View tab, click Save as Text File, and then enter the file name and browse to the location to save
the file.
