Configuring Order Channels
You can configure order channels using the following two
EMC modules:
Order Channels
Can only be configured at the Enterprise level of the system and are available to be used in all revenue centers.
Order Channel Parameters
Can be configured at the Enterprise, zone, or property levels of the system, so that you can define standard configurations and override them where necessary.
One order channel, labeled Default, is automatically provisioned and assigned to all new Simphony 19.6 and later checks. You can rename the default channel. You can also override the default order channel at the revenue center, workstation, order type, and by manual entry.
- Configure the order channel:
- Configure the order channel parameters for each order channel:
- To override the default order channel for a revenue center:
- To override the default revenue center order channel for
a workstation:
- To override the default workstation order channel for an
order type:
Parent topic: Order Channels
