Configuring a Barcode Reader
- In EMC, select the property, Setup tab, Workstations module, and then the Devices tab.
 - In the Peripheral Device Configuration section, click Add, and then select the barcode reader from the Select Peripheral Device Type drop-down list..
 - Select the COM Port Settings (if necessary), and then click OK.
 - Repeat steps 2 and 3 to configure the barcode reader for each barcode reader attached to the workstation.
 - Click Save.
Parent topic: Barcode Reader
