Configuring the Quebec SRM Control Button
You can configure a touchscreen button to allow workstation operators to enable and disable the SRM device locally through the POS client.
- Select the Enterprise, property, revenue center, or zone, click Configuration, and then click Page Design.
- Double-click the page on which you want the button to appear on the workstation.
- Insert a new button.
- On the General tab, select Function as the Type, and then click the right arrow directly beneath the Type drop-down menu.
- Select Fiscal from the Type pane, select Quebec SRM Control from the Results pane, and then click OK.
- Enter a Legend, and click Save.
Parent topic: Sales Recording Module (SRM)
