Configuring the Workstation Employee Fingerprint Sign In Options
- Select the property, click Setup, and then click Workstations.
- Double-click the workstation to use with a fingerprint reader.
- Click the Options tab.
- Select the appropriate security options as described in the following table.
Table 6-6 Employee Security Options
Option Selecting This Option Requires That All Employees … 47 - Fingerprint Scan Required for Employee ID
Scan a fingerprint.
48 - Employee ID or Fingerprint Scan Required for Employee ID
Scan a fingerprint or enter the employee ID number.
49 - Employee ID and Fingerprint Scan Required for Employee ID
Scan a fingerprint and enter the employee ID number.
50 - Mag Card or Fingerprint Scan Required for Employee ID
Scan a fingerprint or swipe an employee ID card.
51 - Mag Card and Fingerprint Scan Required for Employee ID
Scan a fingerprint and swipe an employee ID card.
- Click Save.
Parent topic: Fingerprint Scanning
