Revenue Center Groups
You can create a revenue center group for use when a property hosts an event that occurs in multiple revenue centers. For example, a baseball game takes place in every revenue center at a stadium. When you create the event, you can associate it with the revenue center group rather than selecting each revenue center individually.
Revenue center groups are also useful when multiple revenue centers use the same kitchen or bar to prepare menu items. You can also set a Menu Item Availability record for a revenue center group.
  1. Select the property, click Setup, and then click Revenue Center Groups.
  2. Insert a new record or select an existing record, and then double-click the record to open it.
  3. Select the revenue centers to include in the revenue center group.
  4. Click Save.
