Configuring Reservation Privileges
- Select the Enterprise, click Configuration, and then click Roles.
- Select the role type, click the Operations tab, and then click the Guest Management subtab.
- Select the appropriate options for the privileges. The following table summarizes the privileges associated with reservation functionality and the recommended roles to have the privilege set:
Table 43-12 Reservation Privileges
Option Number Privilege Name Allow the Employee to ... Recommended Roles 32006
Greet Wait List Entry
Greet a reservation request if the party arrives earlier than the time at which the reservation automatically moves to the Wait List
Host, Manager
32007
Mark as No Show
Mark a reservation request as a no-show if the guest does not arrive
Host, Manager
32010
Add Reservation Entry
Create a reservation request
Host, Manager
32011
Edit Reservation Entry
Edit an existing reservation request
Host, Manager
32012
Cancel Reservation Entry
Cancel a reservation request
Host, Manager
32013
Approve Reservation Entry
Approve a reservation that is requesting a date or time outside the acceptable or allowable timeframe
Host, Manager
- Click Save.
Parent topic: Reservation List
