Creating a Section Layout
- Select the Enterprise, property, or revenue center, click Configuration, and then click Page Design.
 - Create the page on which to define the Section Layout.
 - Click Other..., select Table Management, and then select Section Layout.
 - Adjust the Section Layout size to ensure that the text is visible to hosting staff. The text size scales with the Section Layout size.
 - Click Save.
Parent topic: Section Layout
