Configuring Sections
  1. Select the property, click Setup, and then click Section.
  2. Enter the name of the section as you want it to appear to the workstation operator and in reports.
  3. Select the color used to distinguish one section from another when viewing tables on the host page.
    Only tables that are assigned to a section inherit the section color.
  4. Click Save.
  5. Select the property, click Setup, and then click Seating Section Templates.
  6. Enter the name of the section template as you want it to appear to the workstation operator.
  7. Select Add to define a table as part of the template.
    1. From the new record, click the build box to view a list of tables defined for the revenue center. Alternatively, you can enter the Table ID, and then press the Tab key.
    2. Select the section from the available list or enter the Section ID.
  8. Click Save.
