Configuring the Standard Table Management Interface
- Select the Enterprise level, click Setup, and then click Interfaces.
- Insert a record for Standard Table Management, and then open it in form view.
- From the Interface Type drop-down list, select 3 - Table Management.
- From the Communications Type drop-down list, select 1 - TCP.
- In the Timeout field, enter the amount of time (in seconds) that Simphony waits for a response from the standard table management interface before showing a communications failure message.
- In the Ping Frequency field, enter the amount of time (in seconds) that Simphony pings the standard table management server (for example, every 5 seconds).
- Click the Options tab, and then select the appropriate options as described in the following table.
Table 43-2 Standard Table Management Interface Options
Option Description 2 - Enable Interface Log
Select this option to post debug information to the Interface log file.
5 - ON = Use 9 digits for Terminal IDs; OFF = Use 2 digits for Terminal IDs
Select this option to transmit the entire nine-digit workstation ID to the standard table management system.
8 - Enable Offline Posting
Select this option to allow offline posting to the Simphony POS client.
9 - Determine Link Status Using Ping
Select this option to allow the Simphony POS client to ping the standard table management system.
10 - ON = Use 5-digit RVC #; OFF = Use 3-digit RVC #
Select this option to allow the standard table management system posting message to support a five-digit revenue center number. (Otherwise, the posting is limited to a three-digit revenue center number.)
11 - ON = Use 8-digit Check #; OFF = Use 4-digit Check #
Select this option to allow the standard table management system posting message to support an eight-digit check number. (Otherwise, the posting is limited to a four-digit check number.)
- In the TCP Host Name field, enter the name or IP address of the standard table management server for the interface.
- In the Port Number field, enter 0 (zero).
- Click the Properties tab, and select each property that uses the standard table management system interface.
- Click the Service Host tab, and then select the service host that can run the standard table management system interface.
- Click Save.
- Select the revenue center, click Setup, and then click RVC Parameters.
- Click the Interfaces tab.
- Select the TMS Operator to whom a check that is opened by the standard table management system is assigned, before being picked up by a server.
- Select the TMS User Workstation to which a check that is opened by the standard table management system is assigned.
- From the TMS Link drop-down list, select the standard table management interface.
- Click Save.
