Property Ports
Starting with Simphony 19.6, a Secure Port column is now available from the Simphony EMC modules listed below. ServiceHosts now listen on separate HTTP and HTTPS ports for peer communications.
Access the EMC and then navigate to each module by selecting the following:
  • Location, Setup, Property Parameters, Workstations tab
  • Location, Setup, Workstations, Service Host tab
  • Location, Setup, KDS Controllers, Service Host tab
  • Location, Setup, KDS Controllers, Backup Service Host tab
  • Enterprise, Setup, Service Hosts module
  • Enterprise, Setup, Interfaces module
The Secure Port number column is non-configurable by design. You should expect (and allow) increased network traffic from any ServiceHosts assigned to these secure ports.
Table 4-2 Property Ports
Service Port Number Configurable?
ServiceHost version 2
HTTP: 8080
HTTPS: 8087
Only HTTP is configurable
ServiceHost as a Service (no Ops)
HTTP: 8071
HTTPS: 8075
Print Controller
HTTP: 8080
HTTPS: 8087
IP Printer Listening
HTTP: 9100
Yes
Banquet Printing
HTTP: 9100
Yes
KDS Client (Display)
HTTP: 5022
Yes
KDS Controller Service
HTTP: 5023
Yes
KDS Backup Controller Service
HTTP: 5031
Yes
Client Application Loader (server selection screen)
TCP 7300
No
Client Application Loader (property selection screen)
HTTP: 8080
Yes
NetTCPRelayBinding (TMS/Azure)
TCP: 9350, 9351, 9352
No
HTTP: 80
No
Workstations running Oracle Linux for MICROS are preconfigured with firewall rules, and available ports are limited. If this feature is needed, then the firewall rules must be manually adjusted.
