Understanding the Simphony Environment
When planning your Simphony implementation, consider the following:
Which resources need to be protected?
  • You need to protect both customers and employees personal identification data.
  • You need to protect internal data, such as proprietary source code.
  • You need to protect system components from being disabled by external attacks or intentional system overloads.
Who are you protecting data from?
For example, you need to protect your subscribers’ data from other subscribers, but someone in your organization might need to access that data to manage it. You can analyze your workflow to determine who needs access to the data. For example, it is possible that a system administrator can manage your system components without needing to access the system data.
What happens if protections of strategic resources fail?
In some cases, a fault in your security scheme is nothing more than an inconvenience. In other cases, a fault might cause great damage to you or your customers. Understanding the security ramifications of each resource helps you protect it properly.
