SPI Messages
Message Description
Acceptor Contact Acquirer, Security - Code 66
The transaction is declined.
Collect the card and contact the card acquirer's securtity department for further instructions.
Already Paid - Code 38
Pay at Table - the check has already been paid in full.
Approved for Partial Amount - Code 10
The transaction is approved for a lesser amount.
The transaction is approved for a lesser amount than requested. Obtain additional payment for the remaining amount.
Approved, Update Track 3 - Code 16
N/A
Approved, VIP - Code 11
The transaction is approved.
This cardholder is identified as a VIP.
Bank Not Supported By Switch - Code 31
The bank associated with the payment card account is not supported. Use a different payment.
Cannot Complete, Violation of the LAW - Code 93
The requested transaction is illegal and can't be performed.
Capture Card - Code 67
Collect the card.
Card Acceptor, Contact Acquirer, Retain Card - Code 35
The card is not valid. Contact the acquirer and collect the card.
Check is Opened (by other workstation) - Code 26
Pay at Table - the referenced check is open on another workstation. Close the check on the other workstation, then try again.
Contact Acquirer Security Department, Retain Card - Code 37
Collect the card and contact the card acquirer's security department for further instructions.
Cutoff in Progress - Code 90
The terminal is performing the day-end cutoff. Try again when the process is completed.
CVV Validation Error - Code 82
The validation failed. Verify the information and try again.
Do Not Honor - Code 5
Do not honor this card for payment and use a different payment.
Duplicate Transaction - Code 94
The same transaction has already been performed.
Error - Code 6
This is a generic error, no further detail is available.
Exceeds Withdrawal Limit - Code 61
N/A
Expired Card - Code 54
The payment card is expired. Use a different payment.
Expired Card, Capture - Code 33
The payment card is expired. Collect the card.
Format Error - Code 30
The message format is incorrect.
Function Not Permitted to Cardholder - Code 57
The requested function is not permitted with this card. Use a different payment.
Function Not Permitted to Terminal - Code 58
The requested function is not permitted on this payment device. Try on a different device.
Function Not Supported - Code 40
The requested function is not supported with the payment support provider.
Host or Switch Unavailable
The terminal is unable to communicate with the host or switch.
Incorrect PIN - Code 55
The entered PIN is incorrect. Try again.
Insufficient Funds - Code 51
The account associated with this card does not have sufficient funds or credit to cover the transaction. Use a different payment.
Invalid Card Number - Code 14
The card number is invalid. Re-enter or use a different card.
Invalid Transaction - Code 12
This transaction type is not supported.
Invalid Transaction RVC ID or Merchant Mismatch - Code 97
The payment device is registered to a different merchant than the Revenue Center is associated with. Correct the configuration and try again.
Lost Card - Code 41
This card has been reported as lost. Use a different payment.
No Action Taken - Code 21
The requested procedure was not executed. Try again.
No Card Record - Code 56
N/A
No Check Account - Code 52
N/A
No Credit Account - Code 39
This card is not associated with a valid credit account. Use a different payment.
No Investment Account - Code 44
N/A
No Issuer - Code 15
The card is not associated with a valid issuer. Use a different payment.
No Merchant - Code 3
The configured Merchant ID is invalid. Correct the configuration and try again.
No Open Check On This Table - Code 24
Pay at Table - there are no open checks associated with the table number. Verify the information and try again.
No Privilege to Perform Refund - Code 29
The signed in user does not have the privilege to perform a refund.
Pick Up Card - Code 4
Collect the payment card, if possible.
Pick Up Card, Special - Code 7
PIN Tried Exceeded - Code 75
The card holder has entered the wrong PIN too many times. Collect the card.
PIN Tries Exceeded, Capture - Code 38
POS Cancel - Code 0
The transaction has been canceled from the POS.
Posting Failure - Code 45
N/A
Read Card Error - Code 0
The card could not be read. Try again or use a different payment.
Re-enter Last Transaction - Code 19
The last transaction failed. Try Again.
Refer to Issuer - Code 1
Contact the card issuer for more information.
Refer to Issuer, Special -Code 2
Request in Progress - Code 9
Another request is being processed. Try again.
Restricted Card - Code 62
The card has been restricted. Use a different payment.
Restricted Card, Retain Card - Code 36
The card has been restricted. Collect the card.
Stolen Card - Code 43
This card has been reported as stolen. Use a different payment.
Suspected Fraud - Code 59
Fraud is suspected with this card account. Use a different payment.
Suspected Fraud, Retain Card - Code 34
Fraud is suspected with this card account. Collect the card.
Suspected Malfunction - Code 22
A technical error occurred and the transaction was not completed. Retry.
System Error - Code 96
Transaction Approved - Code 0
N/A
Message is never displayed.
Unable to Locate Record on File - Code 25
This error occurs when a transaction such as incremental authorization, finalization, void, or refund is referencing a previous transaction that can't be found or is otherwise not valid. Verify the information and try again.
Unacceptable Transaction Fee - Code 23
N/A
User Cancel - Code 0
The user has canceled the transaction from the payment device.
User Not Found - Code 18
The configured user for this driver is invalid.
User Not Login Yet - Code 27
Pay at Table - the user must log in first.
User Response Timed Out - Code 0
The card holder didn't respond to the terminal prompt within the allocated time. Retry.
