Splitting Off Items
- To split off one item:
- Select the menu item on the check, and then click Split Off Item.
 - Make the changes to the new check entry.
 - To split off multiple items:
- Select a multiple quantity menu item on the check.
 - Using the alphanumeric key pad, select the quantity that you want to split (for example, 2).
 - Click Split Off Item.
Parent topic: Menu Items
