Select a menu item which has required, or has optionally
allowed condiment groups assigned to it. The Popup Condiment Orderer
appears.
Select a required condiment. The Popup Condiment Orderer
automatically advances to the second group, and so on until you have
selected the required number of condiments from all groups.
If your location has set the condiment menu items to have
a default count, or have the condiments set to match the parent menu
items’ count, after the minimum count's threshold had been reached,
click Done to move to the next condiment or
to close the Popup Condiment Orderer.
If you click Done without selecting
the minimum count of a condiment group, the system remains on the
current condiment group and the Done button
text changes from Done to whatever is needed (for example, Select
2 to 3 Steak Sauce Current Count:1). When you use devices running
the Android mobile operating system, you receive an error stating
that the required condiment group is not complete for the parent menu
item.
To modify a previously ordered required or allowed condiment:
Select a menu item (condiment or parent) in the check
detail area. The Condiment Edit Popup appears if it is configured
from the Enterprise Management Console (EMC) RVC Parameters or Menu
Item Classes modules.
To edit a menu item when the Condiment Edit Popup is not
configured:
Select the menu item (condiment or parent) in the check detail
area.
Press the Recall Popup Condiment Orderer function key.
