- Delivery Connector Legacy Configuration
- Uber Eats/Postmates
- Adding a Data Extension Record
- Select the Enterprise, click Configuration, and then click Data Extensions.
Figure 6-2 EMC Enterprise Main Menu
- Click the Insert icon
on the toolbar to add a record, enter the Data Extension record name,
and then click OK.
Figure 6-3 EMC Enterprise Main Menu
- Enter information in the following fields:
Table 6-1 Data Extension Fields
Field Description Table
Select 20 - Revenue Center.
Extra Column Name
Enter
DeliveryPlatformConfigurationData
.Type
Select 12 - Json.
Data Constraints
Select Max Chars: 9999.
Sort Priority
Not applicable; use default value.
Display Width
Enter
150
.Translatable Name
Translatable Help
Figure 6-4 Data Extension Module Fields
- Click Save.
Parent topic: Uber Eats/Postmates
