Distribution
Distribution is an EMC function that enables you to copy records between properties and revenue centers. You can configure records once within the EMC and distribute the records throughout the enterprise to multiple properties and revenue centers without having to create a record multiple times.
Remote Distribution
Remote distribution enables you to transfer data between two Simphony systems. Both the source and destination systems must be running the same Simphony version and hotfix. Remote distribution is database-independent, allowing you to distribute data between a Microsoft SQL database and an Oracle Database in either direction.
Moving data from a testing system into a production system. This allows testing in a pre-production environment before moving to production.
Distributing a new revenue center to the production system.
The Importance of Object Numbers
Object Number: 1
Default Transaction Page: 41
If transaction page object number 41 exists in revenue center 8, the serving period's default screen is set to 41.
If transaction page object number 41 does not exist in revenue center 8, the default screen is set to 0. This is the standard functionality for all types of distributed records. If the referencing object number does not exist, the value is set to 0.
