Menu Item Classes
A menu item class consists of a set of options that apply to similar menu items in a revenue center. A menu item class specifies information, including:
  • The tax class associated with the menu items
  • The two types of menu items: Regular and Condiments
  • Active menu levels after ordering an item from the class
  • The order devices to which the items output
You can configure similar menu items into a class rather than individually setting each menu item’s order device output or condiment settings. For example, the menu items Cola, Diet Cola, and Root Beer all share the following characteristics:
  • Receive the same tax rates
  • Do not require condiments
  • Output to the same order device
Therefore, you can create one menu item class called Soda and make all soda menu items a part of this class.
Related Topics
