Preface
Oracle Simphony is an enterprise transaction processing platform used by businesses that vary in size from single unit to global, franchised, multi-unit operations. A Simphony system manages different food and beverage operations models, including:
Table service
Quick service
Fast casual
Bar
Drive-Thru
Concessions
Retail
Purpose
This Configuration Guide provides system administrators instructions to set up Simphony.
Audience
This document is intended for system administrators of Simphony.
Customer Support
To contact Oracle Customer Support, access the Customer Support Portal at:
Product version and program/module name
Functional and technical description of the problem (include business impact)
Detailed step-by-step instructions to re-create
Exact error message received and any associated log files
Screen shots of each step you take
Documentation
Product documentation is available on the Oracle Help Center at https://docs.oracle.com/en/industries/food-beverage/pos.html.
Simphony Digital Learning
The Simphony Learning Subscription provides additional product knowledge through interactive training, guided video tours, and helpful knowledge checks. After exploring the documentation library, use your Oracle Single Sign On to check out the Simphony learning opportunities at Oracle Restaurants Learning Subscription.
Revision History
| Date | Description of Change |
February 2025 |
Initial publication. |
March 2025 |
Updated the following topics in the Check and Posting Service
(CAPS) chapter:
April 2025 |
Updated Add Delivery Connector in the Order Channels and Types chapter. Removed Telemetry references. Updated Transactions chapter topic. Removed Fast Transactions topic from the Transactions chapter. Moved Configuring the Cash Tender from the Currency chapter to the Payment Tenders chapter. |
June 2025 |
Updated the following topics for Delivery Connectors 24.3
in the Order Channels and Types chapter:
Added certificate details to topic Location-Based API Requirements for Simphony Transaction Services Gen 2. |
July 2025 |
Updated the following topics:
Updated Configuring the Import/Export Service Privileges in the Importing and Exporting Data chapter. |
September 2025 |
Updated Enable Delivery Connectors Access Privileges in the Order Channels and Types chapter. |
October 2025 |
Updated the following topics in the Order Channels and Types
chapter:
Added certificate details to Location-Based API Requirements for Simphony Transaction Services Gen 2 in the Transaction Services chapter. |
December 2025 |
Updated the following topics in the Enterprise Management Console chapter:
Updated Adding a Workstation in the POS Workstations chapter. Updated Configuring Required and Allowed Condiments in the Menu Items chapter. Updated Configuring OPERA Connection in the OPERA Integration chapter. |
January 2026 |
Updated Setting the Condiment Display in the Menu Items chapter. |
February 2026 |
In Delivery Connectors:
March 2026 |
Updated Register with Deliveroo. |
