Printer DIP Switch/Memory Switch Setting when using UB-IDN (IDN02) Interface
Table 32-12 TM-U200, TM-U220, TM-U2300
    DIP SW 1           DIP SW 2
1–1 1–2 1–3 1–4 1–5 1–6 1–7 1–8 2–1 2–2 2–3 2–4 2–5 2–6 2–7 2–8
x x OFF OFF OFF OFF OFF x ON* x x x x x x x
Table 32-13 TM-T88 Series
    DIP SW 1           DIP SW 2
x x OFF OFF OFF OFF ON OFF x x x x x x x x
Table 32-14 TM-T90, TM-L90 (Non-Peeler & Peeler)
    DIP SW 1
x ON OFF OFF OFF OFF ON OFF
Table 32-15 TM-T70
    DIP SW 1           DIP SW 2
Table 32-16 TM-T70II
No DIP SW or Memory SW change is necessary.
Use GS (E command (Fn=11)) to set Serial Port Communication Parameters.
Table 32-17 Legend
OFF ON = Mandatory Setting
OFF* ON* = Recommended Setting
x   = Don’t Care
