DIP Switch Definitions
TM-U200A
- RS-232 serial interface model
Table 32-61 DIP Switch 1
Switch No. Function ON OFF Default Settings 1
Data reception error
Ignored
Prints “?”
Off
2
Receive buffer capacity
40 bytes
ANK model: 1000 bytes
Multilingual model: 512 bytes
Off
3
Handshaking
XON/XOFF
DTR/DSR
Off
4
Word length
7 bit
8 bit
Off
5
Parity check
Yes
No
Off
6
Parity selection
Even
Odd
Off
7
Baud rate selection
4800 bps
9600 bps
Off
8
BUSY condition
Receive buffer-full
Off-line
Receive buffer-full
Off
Table 32-62 DIP Switch 2
Selects number of characters per line (cpl) 7x9 font / 9x9 font
42 cpl / 35 cpl
40 cpl / 33 cpl
Off
2
For internal use only (*1) (Autocutter)
Enabled
Disabled
On
3
Asynchronous
Synchronous with clock
Off
4
Undefined
Off
5
For internal use only (*1) (Semi-autoloading)
For type A
For type B/D
On
6
For internal use only (*1) (Flash memory rewriting)
Enabled
Disabled
Off
7
Pin 6 reset signal
Used
Not used
Off
8
Pin 25 reset signal
Used
Not used
Off
- Parallel interface model
Table 32-63 DIP Switch 1
Auto line feed
Enabled
Disabled
Off
2
Receive buffer
40 bytes
Off
3–7
Undefined
Off
8
Busy condition
Receive buffer-full
Off-line
Receive buffer-full
Off
Table 32-64 DIP Switch 2
42 cpl / 35 cpl
40 cpl / 33 cpl
Off
2
Enabled
Disabled
On
3
For internal use only (*1) (Interface synchronization)
Asynchronous
Off
4
Undefined
Off
5
For internal use only (*1) (semi-autoloading)
For Type A
For type B/D
On
6
Enabled
Disabled
Off
7
Undefined
Off
8
Pin 31 reset signal
Used
Not Used
On
TM-U200B/D
Table 32-65 DIP Switch 1
Switch No. Function ON OFF Default B Default D 1
Ignored
Prints “?”
Off
Off
2
40 bytes
Off
Off
3
Handshaking
XON/XOFF
DTR/DSR
Off
Off
4
Word length
7 bit
8 bit
Off
Off
5
Parity check
Yes
No
Off
Off
6
Parity selection
Even
Odd
Off
Off
7
Baud rate selection
4800 bps
9600 bps
Off
Off
8
BUSY condition
Receive buffer-full
Off-line
Receive buffer-full
Off
Off
Table 32-66 DIP Switch 2
42 cpl / 35 cpl
40 cpl / 33 cpl
Off
Off
2
Enabled
Disabled
On
Off
3
Pin 6 reset signal
Used
Not used
Off
Off
4
Pin 25 reset signal
Used
Not used
Off
Off
5
For type A
For type B/D
Off
Off
6
Enabled
Disabled
Off
Off
7
Asynchronous
Off
Off
8
Undefined
Off
Off
*1: Do not change the settings of DIP switches 2–2, 2–5, 2–6, and 2–7.
Table 32-67 DIP Switch 1
Auto line feed
Enabled
Disabled
Off
Off
2
Receive buffer
40 bytes
ANK Model: 1000 bytes
Multilingual mode: 512 bytes
Off
Off
3–7
Undefined
Off
Off
8
Busy condition
Receive buffer-full
Off-line
Receive buffer-full
Off
Off
Table 32-68 DIP Switch 2
Selects number of characters per line (cpl) 7 x 9 / 9 x 9 font
42 cpl / 35 cpl
40 cpl / 33 cpl
Off
Off
2
Enabled
Disabled
On
Off
3
Undefined
Off
Off
4
Pin 31 reset signal
Used
Not used
On
On
5
For type A
For type B/D
Off
Off
6
Enabled
Disabled
Off
Off
7
Asynchronous
Off
Off
8
Undefined
Off
Off
TM-U220A/B/D (STD)
Serial interface model
Table 32-69 DIP Switch 1
Switch No. Function ON OFF Default A Default B Default D 1
Ignored
Print “?”
Off
Off
Off
2
40 bytes
4 KB
Off
Off
Off
3
Handshaking
XON/XOFF
DTR/DSR
Off
Off
Off
4
Word length
7 bits
8 bits
Off
Off
Off
5
Parity check
Yes
No
Off
Off
Off
6
Parity selection
Even
Odd
Off
Off
Off
7
Transmission speed selection
4800 bps
9600 bps
Off
Off
Off
8
BUSY condition
Receive buffer-full
Offline
Receive buffer-full
Off
Off
Off
Table 32-70 DIP Switch 2
Selects number of characters per line (cpl) (*)
42 cpl / 35 cpl
40 cpl / 33 cpl
Off
Off
Off
2
Reserved (Autocutter)
Enabled
Disabled
On
On
Off
3
Undefined
Off
Off
Off
4
Serial communication set selection
By memory switch
By DIP switch
Off
Off
Off
5
Undefined
Off
Off
Off
6
Reserved (Flash memory rewriting)
Enabled
Disabled
Off
Off
Off
7
Pin 6 reset signal
Used
Not used
Off
Off
Off
8
Pin 25 reset signal
Used
Not used
Off
Off
Off
(*) Selection of dots between characters: On = 2 half dots, Off = 3 half dots
The number of characters per line in the Table indicates for the 76 mm-width paper.
Table 32-71 DIP Switch 1
Auto line feed
Enabled
Disabled
Off
Off
Off
2
Receive buffer
40 bytes
4KB
Off
Off
Off
3
Undefined
Off
Off
Off
4
Undefined
Off
Off
Off
5
Undefined
Off
Off
Off
6
Undefined
Off
Off
Off
7
Undefined
Off
Off
Off
8
BUSY condition
Receive buffer-full
Offline
Receive buffer-full
Off
Off
Off
Table 32-72 DIP Switch 2
42 cpl / 35 cpl
40 cpl / 33 cpl
Off
Off
Off
2
Enabled
Disabled
On
On
Off
3
Undefined
Off
Off
Off
4
Undefined
Off
Off
Off
5
Undefined
Off
Off
Off
6
Enabled
Disabled
Off
Off
Off
7
Undefined
Off
Off
Off
8
Pin 31 reset signal
Used
Not used
On
On
On
(*) Selection of dots between characters: On = 2 half dots, Off = 3 half dots.
TM-U220B/D (US STD)
Table 32-73 DIP Switch 1
Printing mode
Right side up printing mode
Normal printing mode
Off
Off
2
40 bytes
4KB
Off
Off
3
Handshaking
XON/XOFF
DTR/DSR
Off
Off
4
Word length
7 bits
8 bits
Off
Off
5
Parity check
Yes
No
Off
Off
6
Parity selection
Even
Odd
Off
Off
7
4800 bps
9600 bps
Off
Off
8
BUSY condition
Receive buffer-full
Offline
Receive buffer-full
Off
Off
Table 32-74 DIP Switch 2
42 cpl / 35 cpl
40 cpl / 33 cpl
Off
Off
2
Enabled
Disabled
On
Off
3
Pin 6 reset signal
Used
Not used
Off
Off
4
Pin 25 reset signal
Used
Not used
Off
Off
5
Undefined
Off
Off
6
Enabled
Disabled
Off
Off
7
Undefined
Off
Off
8
By memory switch
By DIP switch
Off
Off
Table 32-75 DIP Switch 1
Printing mode
Off
Off
2
Receive buffer
40 bytes
4KB
Off
Off
3
Undefined
Off
Off
4
Undefined
Off
Off
5
Undefined
Off
Off
6
Undefined
Off
Off
7
Undefined
Off
Off
8
BUSY condition
Receive buffer-full
Offline
Receive buffer-full
Off
Off
Table 32-76 DIP Switch 2
42 cpl / 35 cpl
40 cpl / 33 cpl
Off
Off
2
Enabled
Disabled
On
Off
3
Undefined
Off
Off
4
Pin 31 reset signal
Used
Not used
On
On
5
Undefined
Off
Off
6
Enabled
Disabled
Off
Off
7
Undefined
Off
Off
8
Undefined
Off
Off
TM-T88III/IV/V and TM-T70
Serial interface specification
Table 32-77 DIP Switch 1
SW 1 Function ON OFF Factory Setting 1
Ignored
Prints “?”
OFF
2
45 bytes
4 KB
OFF
3
Handshaking
XON/XOFF
DTR/DSR
OFF
4
Word length
7 bits
8 bits
OFF
5
Parity check
Yes
No
OFF
6
Selection of parity
Even
Odd
OFF
7
Selection of transmission speed
See Table 18
See Table 18
ON
8
See Table 18
See Table 18
OFF
Table 32-78 Transmission Speed
Transmission speed (bps) SW 1–7 SW 1–8 (*1)
ON
ON
4800
OFF
ON
9600
ON
OFF
19200
OFF
OFF
bps: bits per second
Table 32-79 DIP Switch 2
SW 2 Function ON OFF Factory Setting 1
Handshaking (Condition or BUSY)
Receive buffer full
Offline
Receive buffer-full
OFF
2
Reserved (Do not change settings)
Fixed to OFF
Fixed to OFF
OFF
3
Selects print density
See Table 20
See Table 20
OFF
4
See Table 20
See Table 20
OFF
5
Setting the conditions that cancel the receive buffer BUSY state (This function is effective when the receive buffer capacity is set to 4 KB.)
Cancels the BUSY state when the remaining capacity of the receive buffer reaches 138 bytes.
Cancels the BUSY state when the remaining capacity of the receive buffer reaches 256 bytes.
OFF
6
Fixed to OFF
Fixed to OFF
OFF
7
I/F pin 6 reset signal
Enabled
Disabled
OFF
8
I/F pin 25 reset signal
Enabled
Disabled
OFF
Table 32-80 DIP Switch 2–3 and 2–4
Switch No. 3 Switch No. 4 Function OFF
OFF
Print density (Standard)
ON
OFF
Print density (Medium)
OFF
ON
Print density (Dark)
ON
ON
Prohibited
Parallel interface specification
Table 32-81 DIP Switch 1
SW Function ON OFF Factory Setting 1
Auto line feed
Always enabled
Always disabled
OFF
2
45 bytes
4 KB
OFF
3
Selects paper sensors to output paper-end signals (default value of ESC c 3)
Disabled
Roll paper end sensor enabled; roll paper near-end sensor enabled
OFF
4
Sets error signal
Disabled
Enabled
OFF
5–8
Undefined
OFF
Table 32-82 DIP Switch 2
Handshaking (Condition for BUSY)
Receive buffer full
Offline
Receive buffer full
OFF
2
Fixed to OFF
Fixed to OFF
OFF
3
See Table 23
See Table 23
OFF
4
See Table 23
See Table 23
OFF
5
Setting the conditions that cancel the receive buffer BUSY state (this function is effective when the capacity of the receive buffer is set to 4 KB).
OFF
6
Fixed to OFF
Fixed to OFF
OFF
7
Fixed to OFF
Fixed to OFF
OFF
8
Interface pin 31 reset signal (Do not change settings)
Fixed to ON
Fixed to ON
ON
Table 32-83 DIP Switch 2–3 and 2–4
3 4 Function OFF
OFF
ON
OFF
OFF
ON
ON
ON
Prohibited
TM-T70II
Table 32-84 Memory Switch 1
| Memory Switch | Function | Setting Value — 48 (OFF) | Setting Value — 49 (ON) | Defaults |
1–1 |
(Reserved) |
48 (OFF) |
1–2 |
Receive buffer capacity |
4 KB |
45 bytes |
48 (OFF) |
1–3 |
Condition for BUSY |
Receive buffer full or offline |
Receive buffer full |
48 (OFF) |
1–4 |
Data processing for receiving error |
Replaced with “?” |
Ignored |
48 (OFF) |
1–5 |
Automatic line feed |
Always disabled |
Always enabled |
48 (OFF) |
1–6 |
(Reserved) |
48 (OFF) |
1–7 |
(Reserved) |
48 (OFF) |
1–8 |
(Reserved) |
48 (OFF) |
Table 32-85 Memory Switch 2
2–1 to 2–8 |
(Reserved) |
48 (OFF) |
Table 32-86 Memory Switch 3
3–1 to 3–8 |
(Reserved) |
48 (OFF) |
Table 32-87 Memory Switch 4
4–1 to 4–8 |
(Reserved) |
48 (OFF) |
Table 32-88 Memory Switch 5
5–1 |
Sets USB power-saving function *1 |
Enabled |
Disabled |
48 (OFF) |
5–2 |
Sets recovery conditions from receive buffer BUSY (Enabled when the receive buffer capacity is set to 4 KB) |
Recovers when the remaining receive buffer capacity becomes 256 bytes |
Recovers when the remaining receive buffer capacity becomes 138 bytes |
48 (OFF) |
5–3 |
Selects paper sensors to output paper-end signals (default value of ESC c 3) |
Roll paper end sensor enabled; roll paper near-end sensor enabled |
Disabled |
48 (OFF) |
5–4 |
Sets error signal |
Enabled |
Disabled |
48 (OFF) |
5–5 |
(Reserved) |
48 (OFF) |
5–6 |
(Reserved) |
48 (OFF) |
5–7 |
(Reserved) |
48 (OFF) |
5–8 |
(Reserved) |
48 (OFF) |
*1: Valid only when the USB interface communication condition is set to the vendor-defined class and the system configuration is set so that the USB driver can support the USB power-saving function.
Function 11
Function 11 — Descriptions
Sets the configuration item for the serial interface specified by a to the values specified by d.
| a | Configuration Item |
1 |
Transmission speed |
2 |
Parity |
3 |
Handshaking |
4 |
Bit length |
Transmission speed settings (a = 1)
| d1...dk | Transmission Speed |
“2400” |
2400 bps |
“4800” |
4800 bps |
“9600” |
9600 bps |
“19200” |
19200 bps |
“38400” |
38400 bps |
“57600” |
57600 bps |
“115200” |
115200 bps |
Parity settings (a =2)
| d1 | Parity |
48 |
None |
49 |
Odd |
50 |
Even |
Handshaking settings (a = 3)
| d1 | Handshaking |
48 |
DTR/DSR control |
49 |
XON/XOFF control |
Bit length settings (a = 4)
| d1 | Bit Length |
55 |
7 bits |
56 |
8 bits |
Parent topic: Printer DIP and Memory Switch Settings
