Setup Overview
Unzip the installation files.
Set up the extension application and configure the interface settings.
Update the Page Design module with new workstation buttons as required.
Configure allergen and nutritional information, and link to menu items according to the required specifications.
Update the database and restart each Simphony workstation (ServiceHost).
Test all applicable use cases and verify the setup.
Parent topic: Extension Application Plug-in for Menu Item Information
