Insert Content: MenuItemInformation_Lang_en-US
Click Insert Application Content, enter the following fields, and then click OK.
Zoneable Key: MenuItemInformation_Lang_en-US
Description: English Language
In the Content Type field, select 23 - Text, and then click Import from a file.
Navigate to the file
MenuItemInformation_Lang_en-US.xml
in theLanguages
folder of the installation package, and then click Open. -
The imported text appears in the Content area.
Figure 17-29 Content Area
Click Save.
Repeat steps 1 through 5 for all language files that need to be installed, ensuring that the Zoneable Key matches the name of each language file.
Parent topic: Extension Application Installation
