OPERA PMS Interface Settings
Posting Related Settings
The following tables list the string names and values to be used in the Content module for the OPERA content text file.
Table 49-1 Posting Related Settings
| Configuration String | Configuration Value |
MAGCARDONLY |
Set to 0 to allow both magnetic cards and keyboard inputs. Set to 1 to limit the entries in the Room Charge event to magnetic cards. |
MAGCARDOVRWRT |
When |
SUPPRESSGSTMSG |
Set to 1 to suppress the message indicator during posting. Enable this setting for high-volume sites. |
SUPPRESSNFOREF |
Non-Room Charge tenders show the Department Code for which they were posted. Set to 1 to suppress this reference. |
REVERSEGST |
Set to 1 to make the guest count negative when the payment is negative (that is, the payment is voided). This feature requires specific configuration on the Front-Office interface to work correctly. |
FULL_DSVC |
Set to 1 to send the full breakdown of the discounts. This requires a specific version of the Front-Office interface. Set to 2 for an additional full breakdown of the service charges. This includes the full breakdown of discounts. |
NO_CONFIRM_GST |
Set to 0 if magnetic cards are used to identify guests. Set to 1 to prevent confirmation of the guest name when posting. |
POST_64TAXES |
Set to 1 to send up to 63 Tax Itemizers to the Front-Office interface. This feature requires IFC8 V.8.7.1.2 or later as well as a certain version of the Front-Office itself. Set to 0 to send only 8 Tax Itemizers to the Front-Office interface. |
SendAllDtls |
Set to 0 to send only the check details of Room Charges the Front-Office interface. Set to 1 to send also the check details of non-Room Charges. |
RESTRICTED_POSTING |
Select to restrict the response returned from the Front-Office
Interface in the Room Charge event. Note that this only works in combination
with the option
RESTR_POSTING_EMPL is configured
correctly. There are two values supported:
RESTR_POSTING_EMPL |
Specify the ISL Option to use with the above option (see ISL Options in the Employee Maintenance module). The valid value for this configuration is between 1 and 8. |
Locator and Message Settings
Table 49-2 Guest-Locator and Guest-Message Settings
RVCNAMELOC |
Set to 1 to have the first line of the locator contain the revenue center name, otherwise the locator name is blank. Workstations operator can overwrite this value when entering the locator information. |
LOCVALIDMIN |
Each new locator is only valid for a certain time. Enter the default time in minutes for which the locator is valid. Workstation operators can overwrite this value when entering the locator information. |
Parent topic: Configuring the OPERA PMS Enhanced Interface
