Enabling High Contrast Visibility Settings
Enable High Contrast visibility settings based on the operating system that you are running on your computer.
- To enable high contrast visibility settings with Microsoft
Windows 11:
- Click the Start button from your computer’s Desktop.
- Navigate to Settings, Accessibility, and then Contrast Themes.
- Select a theme from the Contrast Themes drop-down list.
- Click Apply.
Windows 8.x or Microsoft Windows 10:
- Type high contrast settings in the Search box, and then select High Contrast from the list.
- Select a high contrast theme from the Choose a Theme drop-down list.
- Click Apply.
Windows 7:
- Click the Start button from your computer’s Desktop, and then select the Control Panel.
- Click Appearance and Personalization, and then click Personalization.
- Click the high-contrast theme that you want to use under Basic and High Contrast Themes.
Parent topic: Accessibility Settings
