PreviousNext
JavaScript must be enabled to correctly display this content
Using Audit This Record
Select the Enterprise or property, and then open a module that contains at least one record.
Highlight one or more records, right-click inside the first column, and then select either Audit This Record (single record) or Audit Selected Records (multiple records). The Audit Record tab shows the information for the selected records.
Alternatively, from the EMC toolbar, click Edit, and then select Audit This Record.
To run specific queries on the selected record or records, click the Show Advanced Options link.
Use the same search parameters that are available in the Audit Trail module. See Using the Audit Trail for more information.
