Configuring Pickup Next Check by Service Total Time
Pickup Next Check by Service Total Time is typically used in a drive thru environment to allow a workstation operator to pick up the next check based on the service total time.
  1. Select the Enterprise, property, revenue center, or zone, click Configuration, and then click Page Design.
  2. Double-click the transaction page on which you want the pickup next check by service total time function key to appear on the workstation.
  3. On the Edit tab, select the page area in which to define the Pickup Next Check by Service Total Time key.
  4. Click Button.
  5. On the General subtab, enter the button name in the Legend field (for example, Pickup Next Check by Service Total Time).
  6. Select Function from the Type drop-down list.
  7. Click the black arrow directly beneath the Type drop-down list.
  8. Enter pick in the Name field, select Pickup Next Check by Service Total Time in the Results list, and then click OK.
  9. Position and size the button on the page. Use the Style arrow to change the color.
  10. Click Save.
    To assign default order types (such as Dine In and Take Out) to pickup check buttons, see Configuring Order Types for more information.
