PreviousNext
JavaScript must be enabled to correctly display this content
Printing Check and Receipt Trailers
To configure trailers to print for each tender media record:
Select the Enterprise, property, or zone, click Configuration, and then click Tender/Media.
Double-click the tender record to open it.
Click the Options tab, and then
click the Printing Options subtab.
Set the appropriate options as described in the following
table:
Table 25-1 Trailer Printing Options
Option
Description
22 - Print Check Trailer
Select this option to print the guest check trailer lines
at the end of the guest check.
28 - Print Guest Check Trailer on Fast Transaction Customer
Receipt
Select this option to print the guest check trailer on the
customer receipt when workstation operators use the tender to close
a fast transaction. Deselect this option to prevent the trailer from
printing on customer receipts.
