Setting the Hold and Fire Option Select the revenue center, click Setup, and then click RVC Parameters. Click the Options tab, and then select 70 - Enable Hold and Fire. Do not enable hold and fire if you are using DOM. Click Save. Parent topic: Holding and Sending Items to Order Devices
