Configuring Additional Combo Meal Settings
You can configure additional combo meal options in various EMC modules.
- To prevent tendering with incomplete combo meals:
- Select the Enterprise, property, or zone, click Configuration, and then click Tender/Media.
- Double-click the tender media record.
- Click the Options tab, and then click the Printing Options subtab.
- To prevent the tender from being enabled when a meal is missing a side item, select 85 - Not Allowed With Incomplete Meals.
- Click Save.
- To enable workstation operators to add incomplete combo
meals and placeholder items:
- To control a user’s ability to change non-placeholder side
items added during a previous round for combo meal orders:
- To configure revenue center parameters for combo meals:
- Select the revenue center, click Setup, and then click RVC Parameters.
- Click the Options tab.
- To enable the combo key to function with Auto Combo Meal recognition, select 51 - Allow Auto Combo Meal Recognition with the "Combo" key.
- To enable the Auto Combo Meal recognition to create combo meals from menu items that were ordered in previous rounds, select 52 - Allow Creation of Combo Meals from Previous Round Menu Items.
- To show a list of combo meal choices when the workstation operator attempts to create meals from menu items already on the check, select 55 - Show Combo Meal Choices.
- To have the application create combo meals from the menu items added to the check in the current round, select 58 - Auto Combo Items On The Fly.
- Click Save.
- To configure menu item class options:
Parent topic: Combo and Fixed Price Meals
