Configuring Popup Condiment Orderer Settings for Revenue Center and Menu Items
The system requires one Popup Condiment Orderer for initial condiment selection and editing.
Assign the Popup Condiment Orderer to either a revenue center or to a Menu Item Class; the Menu Item Class setting overrides the revenue center setting.
  1. Assign the revenue center settings:
    1. Select the revenue center, click Setup, and then click RVC Parameters.
    2. Select the following popup options:
      Table 17-15 Revenue Center Condiment Popups
      Field Select the Popup Condiment Orderer page to appear when the workstation operator
      Default Condiment Ordering Popup
      Adds a menu item with required or allowed condiments (where allowed condiments are enabled in the orderer) for the revenue center.
      The default is 0 - None.
      Default Condiment Editing Popup
      Selects a menu item with required or allowed condiments (where allowed condiments are enabled in the orderer) in the check detail area for the revenue center.
    3. Click Save.
  2. Assign menu item settings:
    1. Select the Enterprise, property, revenue center, or zone, click Configuration, and then click Menu Item Classes.
    2. Double-click the record for the parent menu item class.
    3. Select the following popup options:
      Table 17-16 Menu Item Class Condiment Popups
      Condiment Order Popup
      Adds a menu item from this class with required or allowed condiments (where allowed condiments are enabled in the orderer).
      To have the menu item class use the default Condiment Order Popup assigned to the revenue center, select 0 - Use Revenue Center Parameter.
      Condiment Edit Popup
      Selects a menu item from this class with required or allowed condiments (where allowed condiments are enabled in the orderer) in the check detail area.
      To have the menu item class use the default Condiment Edit Popup assigned to the revenue center, select 0 - Use Revenue Center Parameter.
      To use gestures, select No Popup for the menu item class, and use the Recall Popup Condiment Orderer function key to edit required condiments that were previously added.
    4. Click Save.
