Enable Delivery Connectors Access Privileges
To access Delivery Connectors, users must first have the privileges enabled for them from the Simphony Enterprise Management Console (EMC). See Configuring Permissions for more information. In addition, the privilege must be activated for any location level manager role who needs access to Delivery Connectors.
To assign Delivery Connector privileges:
  1. Sign in to the Simphony EMC.
  2. Select the Enterprise, click Configuration, and then click Roles.
  3. Double-click the record of the role for which to set user permissions (for example, Manager).
  4. Click the EMC Modules tab.
  5. In the File column scroll down to the Revenue Center Modules section, and then assign the appropriate access privileges for the role (View, Edit, Add, and Delete).
  6. Click Save.
