Enable Locations
Delivery Connectors allows activation and deactivation of a store’s delivery service provider integration, and supports Uber Eats integration.
  1. Sign in to EMC.
  2. Select the revenue center, click Setup, and then click RVC Paramters.
  3. Click the Interfaces tab.
  4. In the Delivery Platform Integrations area, click the Launch Provisioning Portal button. A browser window opens and loads the Provisioning Portal.
    Do not bookmark the URL; access this only through the EMC.
  5. Log in to the Uber Eats provider with your credentials for Uber Eats or Postmates. A list of stores that are eligible for provisioning appears.
  6. Select one or more stores using the check box, and then click the Enable button.
    Copy the associated store ID(s) for use later.
  7. Close the browser and continue the configuration process.
