Configuring a Total Price Threshold Discount
- Select the Enterprise, property, or zone, click Configuration, and then click Discounts.
- Double-click an automatic discount record to open it. From the General tab, set the Activation Type field to 1 - Automatic (Automatically applied, operator cannot enter) from the drop-down list, and then check the Enabled checkbox.
- (Optional) Select the Effectivity tab and set the discount’s Start and End dates accordingly.
- Select the RVC Type tab and then select the revenue center(s) where the discount is to be active.
- Select the Menu Levels tab and ensure the Main and Sub levels are enabled for when the discounts can be applied (typically, all Main and Sub levels are enabled).
- Click the Auto tab, and then select 3 - Total Price Threshold from the Automatic (Automatically applied, operator cannot enter) drop-down list.
- (Optional) Enter a Priority for
the discount.
Priority determines the order in which discounts are calculated. By default, this field is blank (0) for all discounts, meaning that discounts are calculated at the same time. If you enter a priority, the workstation calculates all discounts in priority 1, then in priority 2, and so on. Priority zero (0) discounts are calculated last. The priority field allows Simphony to calculate discounts more efficiently.
- (Optional) Select the appropriate Constraint
Type:
1 - No Constraint: Select this type to maintain the system’s legacy discount behavior, with no constraints. This is the default setting.
2 - Menu Item: Select this type to apply constraints to specific, individual menu items such as a Cheeseburger, Chicken Sandwich, or Large Coffee.
3 - Family Group: Select this type to apply constraints to menu items assigned to a specific Family Group, such as Appetizers, Burgers, Salads, Beer or Wine.
4 - Major Group: Select this type to apply constraints to menu items assigned to a specific Major Group, such as Food, Alcohol, or Retail.
See Discount Constraint Types in the Discounts chapter for more information.
- To use promotion prices that appear in the Menu Item Groups module for the discounted menu item, select Use Price in MI Group Detail.
- In the Trigger section, configure
up to eight unique triggers to invoke the discount. You must configure
the triggers in sequential order.
Trigger MI Group: Select the menu item groups that will trigger the discount award. When the total amount of all items on a check exceeds the amount configured for the trigger group, the discount will be applied to all items in the Award Menu Item Group.
Trigger Condiment Group: Select the condiment menu item groups to use as the trigger for the discount, if any. For example, If customers can get a bagel for 0.50 when they add cream cheese to any bagel, cream cheese is the trigger condiment and bagel is the trigger menu item for the 0.50 discount.
Total: Enter the total amount of corresponding trigger menu item group items customers must order before applying the discount (that is, to activate the Award Menu Item Group). For example, if you are giving 15% off all shirts for a purchase of 80.00 or more, enter 80.00 in this field.
- In the Awards section, configure up to eight rewards for
the discount:
Award MI Group: Select the menu item groups to use as the award group when the total amount of all items on a check exceeds the Total configured for the Trigger MI Group.
Award Type: Select the discount type.
Percentage Off: If this is a percent discount, enter the percentage to discount from each item in the Award MI Group.
Amount Off: If this is an amount discount, enter the amount to discount from each item in the Award MI Group.
Amount Substitution: If this is an amount substitution discount, enter the price to charge for each item in the Award MI Group.
Max Count: Enter the maximum number of award items that can be discounted on a single check. If set to zero (0), the maximum count is unlimited.
- If you set a Percentage Off discount from the Award Type column, enter the required percentage of discount from the Percent Off column.
- If you configured an Amount Off discount
amount of discount from the Amount Off column.
(Optional) For amount off discounts, from the General tab, you can enter a minimum and maximum amount for each discount using the Min Amount and Max Amount fields. - Click Save.
Related Topics
Parent topic: Discounts
